Plug question
Stresst
What is the differance between NGK (7397) TR5IX Iridium IX and the AC Delco 41-110?
Looking for new plugs for 07 Denali and I think I have it limited down to these two.
Wires, I am going with 748RR.
Any other suggestions?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
unless you are modifying your ignition stick with delcos. you can use autolite equivalents. testing and calibration of of electrical parts were based on delco or delphi parts mostly. ngk were originally for import market and as such are typically designed for such just. because a maker has a crossover part does not mean it's better. when you want to modify your ignition system among other things a different plug may be in order.
S
Stresst
K, thanks!
Drewphil
