Platinum Gauge Cluster from Escalade 03-06
krt
So Cal
This has been in my 06 Yukon for about 2 months with no issues. I decided to send my original cluster to be updated so my mileage would be correct. This cluster has 48012 miles on it.
How about $270 shipped?
Video on YouTube:
adventurenali92
Big Bear Lake, ca
I'm looking at swapping this cluster into my denali. However here is my question. My gauge cluster doesn't have the electronic transmission window. Mine just has a little yellow indicator light under each gear.if I pick this one up from you and swap it into my Denali would that cause any issues? Heres a pic of what I'm talking about on my cluster.
krt
krt
So Cal
The cluster I have has the gear indicator (PRND321) in green if that is what you are talking about.
fiatdale
Houstons Best
Houston
Big Bear - It will work just fine, completely plug and play. Only thing that wont is mileage - it will not transfer over. That "window" is there because the bezel is different. The actual guts of the clusters are identical.
adventurenali92
Big Bear Lake, ca
Right I know the innards are the same. But will it still work even though the shift bezel is different from mine? And i would just need to take it to a gm dealership and have it programmed to my vin and mileage right?
fiatdale
Houstons Best
Houston
Yes - Everything will still work. The PRNDL looks so much better in the Platinum and 06 cluster than the previous.
gmsteve-1
