Pics of tahoe lowered 3/5 on 26's?
Whatsup
Thinking about doing this. I have 26" u2 55's with 305-30-26's. Wondering If anyone has pics of a tahoe lowered 3/5 on 6's. And does anyone know how Steve meades tahoe is lowered?
thehoe92
fo sho
The916
Steve originally had the DJM setup in his tahoe for a 3/5 on the same rims and tires
that included control arms, shocks, 5" coils and a couple other hardware pieces
now he has AirRide technologies titanium shocks with the ride pro digital ride height sensors combined with the DJM upper and lower control arms and McGaughy's spindles
here was his 3/5 on 25 series tires
W
Whatsup
Damnnnn, I love his tahoe. Do you know how much that 3/5 kit cost?
1lowhoe04
Fort Worth Texas
i had the 3/5 djm on mine i paid 350 craigs list but now i am tucking 24z with the 3/5 and 2500 hd torsion keys c notched cut springs shock relocaters and it rides like a caddy !!!!
Modded
That Guy
Like Bigblue said I do have a 3/5 on 26s, here is a pic of it below and in my sig.
If you have the same model Steve has yours will be lower with a 3/5 being that the new ones are higher up from factory.
W
Whatsup
Yeahh, mines the same as steves but black. The only thing idk about is he's got 295/25's and I got 305/30's will it rub like hell?
Modded
That Guy
If you run a 295/25/26 it won't rub much if any at all, run a 305/30/26 with a 3/5 on a NBS you are going to be doing a lot of cutting and malleting to stop the rubbing.
Problem is the 295/25/26 is only made by Pirelli and it will run you atlest $1400 for a set of them $$$$$
NORCAL SS
SUV SUSPENSION GURU
got to pay to play ;) that being said the kit i have wiht the 295 25 26 still rides great.
NORCAL SS
SUV SUSPENSION GURU
With my 3/5.5 kit on 305 35 24 there are no issues. Now seeing that your on a 305 30 26 which is about 3/4 of a inch taller there will be some rubbing but nothing major.
on 26x9.5 with 38mm offset you will be ok wont be that bad.
W
Whatsup
im pretty sure i have 26x10s id the offset though
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
idkk**
Modded
That Guy
Depends on what you clasify as major, i'm pretty sure its gonna rub real good.
And rim width does not matter, the width of the tire is what matters because that is what is rubbing, not the rims. A 305 series tires on an 11" rim is still just as wide as a 305 series tire on a 9" rim.
Lastly a +38 offset or so will help minimize rubbing.
W
Whatsup
i know that. but my wheels dont stick in nor do they stick out on my sierra..
brucebruce45
2-3 drop 26x10 295/30/26 tire. yes a 305 will rub like hell on a 3-5. yes you will have to cut and remove the windshield fluid resevoir. yes get the 295/25/26 pirellis. anything else you need spoon fed?
W
Whatsup
im new at this shit bro, youve prolly been spoon fed too, is that a 2-3?
---------- Post added at 12:38 AM ---------- Previous post was at 12:34 AM ----------
plus your the first ******* ive came across on here
brucebruce45
This is why u can't be helped Bc u can't read. The first two numbers in my post is 2-3. I Havnt been spoon fed bro. I had 30s on my tahoe and I didn't go around asking what all I'd have to do to make em fit. I used my brain and went to work
W
Whatsup
should have said THIS IS A. can i get a link to that kit
Drewphil
