Permanently Disabling Park Assist & Rear Air Compressor
604Escalade
Is there a fuse I can pull to disable the rear parking assist and the air compressor? I replaced my rear shocks for the third time, and went with a coil-over set up. I'm running new OEM shocks up front. I've heard that if I pull the fuse out for the compressor, the front shocks will stop working? The service parking assist, and suspension system messages are getting annoying to look at.
Stresst
Annot makes a kit I believe to delete the codes.
fiatdale
Houstons Best
Houston
Search for Autoride Bypass thread. It will tell you how to bypass the autoride code. As for the park assist, Im not sure.
McLoud24
