Passenger window won't work
Cameron
Andalusia, Alabama
So here's what happened i had the windows cracked at work and it rained a little bit when I came home it was fine later on it just quit working I have no power to the passenger side except to one small wire on the plug and the locks work on the passenger side via passenger switch and driver switch both work and on the drivers side both the locks and windows work except the passenger front which should mean the front driver switch is damage such as the circuit board in the switch what's the chances of that I need this fixed ASAP please help
Cameron
Cameron
Andalusia, Alabama
Also the passenger window motor is good I had to jump it with a battery charger to get it to roll up it's about to rain
SunlitComet
OBS Jedi-Do Good
unknown at this time.
IF the driver side switch can control any passenger window but not that windows own switch then that windows switch is partly faulty or the power supply to it is or the drivers lock out switch circuit has an open somewhere. the wire that carries power to any non-driver window switch on a 4 door hoe via the wires going thru the door frame is colored dark blue. when the key is on.
Cameron
Cameron
Andalusia, Alabama
Well they just started working again I disassembled them and cleaned the contacts may have still been moisture going to give it a couple of days and if it still works I'm going to put it all back together and get a switch later on they're kind of pricey
AdrienR
