Paint pricing?
Blazed
Accepting Donations
How much are your body shops charging you per panel? I'm interested to compare what pricing others are getting versus the quotes I've been given.
NathanJax
Vacation Nathan
Jax, Fl
It depends on a lot of things. How much prep is involved? Just sand and shoot or bondo and dent pullers?
Donnie Yukonie
Yates Caretaker
Ill do it for the cost of the Rustoleum spray paint , so bout oneFiddy
In all seriousness it will vary upon condition of your existing body work and what color paint ect…..
soulsea
Bar
Also which panel matters a lot. For example a bumper is easy to remove and paint, a front fender on the other hand is a pita.
Ponchonutty
New Washington, Ohio
I painted my '80 TA with PPG base/clear with mostly original paint. This is the before
During
After
Total cost for me to do this was about $975 (not including decals). Took me about 30 hours of work time. Highest quote I got to do the whole car was $8500 and the lowest was around $5500.
Again, it depends on the work to be done. Also can depend on area you are at. Here in Ohio should expect about $95 an hour plus materials used. Spraying black is much more cheaper than say red or silver.
Goodinblack
I Like Tacos
Dirty South
LOVE the TA.
I see why your SIG name is PonchoNutty ;)
I had a '79 base with a 301 normal aspiration....... trashed it.....and I put a 400 in real Pontiac. . :cool:
There were so many TAs with the olds 403.
Ponchonutty
LOVE the TA.
YUP. I for what ever reason have always loved the 2nd gen firebirds. I have owned a bunch over the years. I too had another '80 TA with the non-turbo'd 301. It was my very first car I bought when in highschool. It was certainly a turd for sure but these days, there are plenty of guys getting decent performance out of those little motors. That PACE car after I played with just adjustments actually ran pretty well. Oh well, 'nuff hijacking here lol.
fiatdale
Houstons Best
Houston
Too many factors. If its white, its easy to paint one panel. If its metallic / pearl, it must be blended to the next panel. Panels will need to be de-trimmed, prepped, etc. Send me your quote and I can tell you if its close. I do this crap every day.
Ponchonutty
Well to correct your statement a bit.....White is easy to spray if you are lazy on the prep because it will mask most of what was done wrong. White however is a PITA to match at times especially if you don't properly clean your equipment in between painting. A little contaminate can adversely change the hue of white.
Gzes
the drifting 2dr
Wichita tx
Yep and white with oearl is even harder.... Gonna have to get my hood n fender done diamond pearl white on the prelude...
Ponchonutty
YUP!!!! Back in highschool my dad had a nice white monte carlo SS that I decided to smoke the tires off when leaving school. A tire popped the bead and I put it in the ditch. Luckily it wasn't too bad but messed up a fender and it needed some paintwork. He decided to change it to pearl white. A friend that I knew was painting it and had some issues during the process. Mind you this was in the beginning of the base/clear days. I think that car basically got painted 2 complete times lol
Mlstammerjr
