P0420 code
osidesurfer365
San Diego
Check engine light went on the other day and Onstar notified me it was P0420. I replaced all 4 O2 sensors with AC Delco ones. Do I need to drive a certain amount of miles before the check engine turns off. Hoping I don’t have to replace the actual converter. Thanks
Matthew Jeschke
Sahuarita, Arizona
You can delete codes with a scanner. Or disconnect your battery for 10 minutes. Then reconnect and start up truck. Battery method will also whipe out your fuel trims so may run a tad rich for a short while.
At least that works on older stuff. My truck is 2001.
If code comes back maybe another issue / need further troubleshooting.
Before anything else i wojld double check connectors. Also aways nice to have a cheap scan tool, some can read sensors themselves, then you know immediately if is disconnected or reading wrong.
Sent from my SM-G925V using Tapatalk
osidesurfer365
osidesurfer365
San Diego
Thanks for the response. Turns out after driving it about 70 miles it turned off and no other codes came on when I plugged the scanner in.
Jumpshot12
