P0300 Still there, after cap rotor
OilBurner2003
This is going to be a part two to my previous post, I replaced the cap and saw no significant change. I decided to say screw it and wanted to look at the condition of my new AC DELCO plugs, which are only 6 months old. Well, popped one out, found this. Now to me, that looks fouled. Fouled enough to cause a misfire? I'm not sure, I'm sure someone on this site with more knowledge than me could tell me. If it's as bad as I think, it's only a 6-month-old plug that has maybe 200 miles on it. So... What the hell? My cap was toast, and my plugs look bad. Now this plug also looks like it has oil on it, from a leaky valve cover from what I've been told. I think my problem was I had a bunch of leaks and broken parts I didn't know about until AFTER I did the cap, rotor, wires, and plugs. Maybe that prematurely helped with breaking my cap and plugs? I had a guy tell me to look at the vent screen under the rotor, which I will do. But that's the end of my problem-solving ability's. I'm going to change the plugs because they all look like that and see if those change anything. If not, I'll send it to a mechanic and have him find the problem. Hell, it could even be my injectors at this point, I have no clue how to check them. Any and all advice is greatly appreciated! Wanted to say, this problem started 6 months ago after we replaced the wires, cap, rotor, and plugs. So, something really makes me think we got a bad part somewhere. Update! Found a bad spark plug wire. Put my head down low to engine to hear how it was sounding, I could hear an electrical arc! It was zapping the exhaust manifold and burned through. It must have come loose from its fastener somehow. This must have been the problem, or at least the most major one. Will replace and update on the condition once replaced, thanks everyone! Although it doesn't explain multiple cylinders misfiring, it's a great start.
Fless
Moderator
People's Republic of Colorado
I don't see anything wrong with the plug, the electrodes are clean. If you have a leaky valve cover the oil wouldn't get into the cylinder, it'll stay on the outside of the plug. That won't necessarily cause a misfire.
O
OilBurner2003
Ah, thank you for clearing out that valve cover thing. I did wipe the electrode to inspect the material, but what you said opens up more possibilities then. Then It's probably a problem out of my league then, will do some last-minute checks before I have someone else take a look at it. Thank you!
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
This post is in the wrong section, for one. The plug looks fine, IMO. If enough oil leaks from a valve cover and damages the wire, then you can have a miss but oil around the base of the plug, where it threads in, will not cause a misfire, that I have ever seen. AC Delco cap and rotor, correct? I seem to remember from the other thread that they are. Did you do a wet and dry compression test?
O
OilBurner2003
I have not done any compression tests; I am going to go test each spark plug wire with a multi meter and also just see if there's anything staring at me in the face like a burned/cut wire. I thought engine and drivetrain was a good spot to post this lol. I will also research how to do a compression test, I don't have the tools at the moment, but that's a good thing to look into.
OR VietVet
Willamette Valley
You posted in 2021 and newer section. You have a much older rig. Find that section and then of course, the Engine and Drivetrain is correct. Perhaps a mod can fix this and move it. @Fless, can you please help.
OR VietVet
Willamette Valley
Huh, strange. Apologies.
No need for apologies here. Just pointing it out that if in wrong section, the right people will not see the post and you get left with no answers. It all comes out in the wash eventually. I did reach out to @Fless, a moderator, to switch it to correct section.
O
OilBurner2003
appreciate it! You and the rest of this site have been a great help.
bsamole
Sparks, Nevada
I agree the plug looks okay. Since the problem started 6 months ago after replacing the wires, cap, rotor, and plugs I would suspect the wires, cap, rotor or plugs are the cause. The least expensive approach is to verify the plug wires are connected in the correct order. Do you still have the old wires if so I'd replace the new wires with the old and see what happens. Make sure you have the correct rotor and the correct cap and the cap and rotor are seated correctly.
O
OilBurner2003
Hey, thanks for the advice! I discovered a while ago that I had a burned spark plug wire that fell out of the mount and was rubbing against the exhaust manifold and arcing to the block. Since then, no misfires have been present, and p0300 has not come back. for now, at least...I am now chasing an oil pressure sending unit.
preacherman22
What is a wet and dry compression test? Please explain if possible.
OR VietVet
Willamette Valley
Remove all plugs, do a DRY compression test on all 8 cylinders, with a battery charger attached and charging. If you have any weak cylinders, squirt a small amount of oil in the spark plug hole and do the compression test again on that cylinder. That is a WET test. If compression increases, that means the oil sealed at the piston rings and brought the compression up and you have rings problem on that cylinder. If compression stays the same, the compression problem on that cylinder is located in the valve train.
Escalade2007
