overheats when ac on
jdawg901
memphis tn.
it doesnt happin right away but i can drive around but when i come to a stop for a minit the temp rises slow to about 210 and it sounds like my fans are blowin really hard it almost sounds like a 18 wheeler then ill turn the air off temp goes down but still have the sound untill i let it sit for a while changed therm. and coolant temp sensor can anyone help out
haks310
Got LEDs?
SoCal
Yeah, check your fan clutch. Idle the engine until you get to operating temperature, turn it off and spin your fan. It should not easily spin more than 2-3 times. If it does you will need a new fan clutch.
jdawg901
jdawg901
memphis tn.
Its a 95 tahoe
---------- Post added at 07:12 PM ---------- Previous post was at 07:06 PM ----------
Just got off work cut the truck off a spun the fan in both directions.it spins more than 2 or 3 times both ways with out any resistance
ravingmadman
Chief Knuckle Buster
Greater Seattle
Cool!! You need a new fan clutch. You'll need a little cool guy tool (rentable from O'Reilly's) to get the fan off, and then it is just a couple bolts. Too easy. :headbang:
It will suck if you have to pull the radiator out though. You'll want to remove the fan shroud- there are a couple bolts across the top of the shroud, and a couple about halfway down on the sides of mine, but then again, mine's a '99. Hope that helps!!
haks310
Got LEDs?
SoCal
All you will need to do is remove the top fan shroud, no need to remove the radiator, you wont need a special tool to remove the fan either. If I recall it is just 4 nuts holding the fan clutch/fan assembly to the water pump, once you get that off, remove the fan clutch from the fan, you are done.
I would check your water pump while the fan/fan clutch assembly are off. Look for leaks and the such. Water pumps usually tend to give out around the same time fan clutches do. If you are like me you will just go and replace that also.
ravingmadman
Greater Seattle
+1
My '99 takes a tool to get the stupid coil spring on the front of the fan off. 95 != 99 Derrrr... :shrug:
ravingmadman
Greater Seattle
wikipedia: http://en.wikipedia.org/wiki/Fan_clutch
"A fan clutch is a thermostatic device that exists as an integral component of certain automotive cooling systems. When the engine is cool or even at normal operating temperature, the fan clutch partially disengages the engine's mechanically-driven radiator cooling fan, generally located at the front of the water pump and driven by a belt and pulley connected to the engine's crankshaft. This saves power, since the engine does not have to fully drive the fan.
However, if engine temperature rises above the clutch's engagement temperature setting, the fan becomes fully engaged, thus drawing a higher volume of ambient air through the vehicle's radiator, which in turn serves to maintain or lower the engine coolant temperature to an acceptable level.
Most fan clutches are viscous or "fluid" couplings, combined with a bi-metallic sensory system similar to that in a thermostat.
Normally fan clutches are fairly reliable, but sometimes they fail. A common symptom of fan clutch failure is overheating at idle or in heavy traffic. Bad fan clutches can also cause poor performance of the car's air conditioning system because the fan also cools the air conditioner's condenser, which is directly in front of the radiator.
Another potential symptom of fan clutch failure (always drawing air at a high rate) in a cold weather climate is that the heating system blows lukewarm air never delivering sufficient hot air."
haks310
Got LEDs?
SoCal
Yeah, my brother has a 99 also and hates me when he sees how easy some parts are to replace.
ravingmadman
Greater Seattle
Yeah, my '77 Blazer- I can just jump in, and sit next to the engine in the engine compartment. Tahoe- eh, not so much...
jdawg901
jdawg901
memphis tn.
Do i have to take off the belt and also could the fan cause my ac to blow poorly and in da winter blow warm until driving .when i say poorly it dosent cool the truck maybe the front saet with the vents pointed at u
haks310
Got LEDs?
SoCal
Yes you do but it is simple, and yes that could be one of the causes of a bad clutch fan.
jdawg901
jdawg901
memphis tn.
Well i changed out the fan clutch no over heating good air but still have that big fan sound
haks310
Got LEDs?
SoCal
Yeah, do not worry about it. How did your water pump look?
jdawg901
jdawg901
memphis tn.
looked fine to me a little rust around the area but most of the motor has a little rust here and there but no leaks i guess problem solved have another issue but thats another thread post in a minit
ZaZaZazzels
