oil level low on message indicator?
Coolade07
i have about a little over 51k on the truck. i have my oil changes 3-4k religiously.
after my last change....the message "oil level low" came up 1500 miles or so. im still at 78%.
anyone encounter this? is it a minor prob? take it to the dealer?
and i only use full synth.
zach2011
Platinum Member
Check under the hood and make sure the level isn't actually low. I mean I know you got it changed ~1500 miles or so, but I'd check anyways to help narrow down the problem.
LILC509
After you check for leaks and all that good stuff, you will come to find out that there arent any. From what I get from you ID is that you have an 07. I have an 07 also and GM is looking into it for all the oil consumption. It is within GM specs to add a quart every 1K miles. But if its more than that then they will put you on list and once GM sends out a bulletin then they will contact you. Dont wait for the bulletin anytime because this has been ongoing for about 2-3 years now. New engine is the only way to get rid of the issue.
Coolade07
Coolade07
werdup....i checked the levels. its good. checked for leaks. none at all. and yes it is a 07tahoe. did you head up to the dealers service dept. about this?
thanks for the input everyone!!!
David4Jesus
Augusta, Ga
Yep same here. Had GM change my oil, add oil came on, I checked level and for leaks and nothing. Took it to jiffy lube just to have changed again to be safe the oil they drained was full and perfect and after their change the light came on again. Who do we see about this awesome list? So its not a sensor?
fixxxer88
It most likey is an oil sensor. I had the same problem about 10k ago. Had 75000 at the time i kept getting that oil level low on the DIC. I checked the oil level all the time and it was ok, and defiantly found no leaks. I went to autozone and picked up a new sensor (30 bucks) and swapped it out. Worked like a champ.
To locate the sensor, Look under your truck on the engine oil pan near the oil plug. The sensor is forward of the oil plug, on the same side of the pan. Its a white/off white colored plastic thing that has 2 wires sticking out of it. Use a small flat bladed screwdrive to pop out the connector on the sensor. Use a wrench or socket to unscrew it a few turns, then it should be unscrewed the rest of the way by hand. (make sure your oil is drained). Slap on the new oring Install the new sensor in the reverse of the install, but do not over tighten. And make sure you put on the NEW o-ring. Reinstall the connector, (only goes on one way) and add your oil. Make take a few minutes of running for the PCM to register the new oil sensor correctly, but it should work the first time.
llllljrlllll
los angeles
I went through the same thing. Dealer said it was the type of filter being used. They recommended using delco filters because it has a plug that other filters don't have. Change your oil with a delco filter. That's what I have now, and problem went away
OklabyGodhoma
Normal....er, Norman, Oklahoma
BULL FRIGGING SH*T......dealers and their Delco filters. There are many threads on filters and oil and I have also added to them. There are cheap and expensive filters but bottom line is no one specific brand is the magic bullet. Personally I only use WIX because of construction and filter media and Delco is a decent filter as well as Purolater and others. Fram not so much, and stay away from the "managers specials" or the cheap crap out there. Bottom line is if you are using ANY quality filter the problem doesn't lie there....it's in the sensor, plug, wiring, etc. Tell them to get off their dead and dying and act like real mechanics and diagnose and fix the real problem. Most problems of this type come from electrical malfunctions. Have you been off roading, had excessive wet weather, snow, or possibly a road hazard hit.
Now all of this applies IF you have made sure that some road hazard hasn't damaged the oil pan and the filter and drain plugs are both properly tightened. Most trouble shooting properly done takes the problem and cuts it in half. Examine every component til the point that you are sure it isn't the problem or part of the problem and then move to the next. Over the years I was a Quality Assurance Manager I can't tell you the number of times that my mechanics missed a wire that had become chaffed and was intermittently rubbing someplace and sending bad information to the gauges. Remember even if you aren't mechanically inclined you are paying someone who is.....you have the right to ask pointed questions and expect honest informed answers. One last thing to consider....if your pressure was always high and suddenly dropped and you have changed everything discussed here then it is time to consider the oil sump pump....the dealer won't go there by himself but as the customer don't be shorted.
LILC509
I just went back to the dealer for them to put a "shield" because its still burning oil more than GM standards. Also if you surf the net on Google and hit oil consumption for 07 tahoe or yukon you will find a lot of people with this problem. I even was told by one of the service tech's he highly doubts the shield will remedy the problem because its the AFM in those particular engines.
I know GM is on this forum. GM do you have anything to say about what is going on with our SUV's. My vehicle has been in the dealership service department in and out since I bought it 12/2009 checked for leaks none at all and through oil consumption test multiple times, its not only me having the problem but a lot of GM consumers having this problem that own 07 Tahoe, Suburban, Yukon, Yukon XL with the 5.3L engine that I know of maybe even Sierra and Silverado. Two of my friends here in town had the same problem as me, they got tired of taking their Yukon's to the dealership and nothing being solved so they traded their vehicles for Lincoln Navigator and Toyota SUV. So far you have lost many customers because of not dealing directly with this issue. You are about to loose another and many more. The problem is from the AFM system. Replace the engines with current model engines and there wont be a problem I gurantee it. I dont know what happened to your 2007 production but it really was crap.
Sorry for the rambling but just had to get it off my chest for the second time, the first went to the dealer but they cant do nothing if they dont get "authorized" to replace the engine.
jeff2007 Yukon
