Odd problem
Ripsaw223
Marion indiana a
K now on my 02 z71 I have barn doors yea I know it sucks but any ways . Some times it makes the door locks go off back and forth and I'm sure it's cause of those dam doors has any one had this problem and is Thier any fox for this thanks for the help .
Infinitrium
If you have remote unlocking with one of those key fobs, try taking the battery out of it
Oxnard,california
Did u fix this problem im having the same issues
ccapehartusarmyINF.(ret)
Gilbert AZ
okay my tahoe had barn doors and i have a suburban now with barns and ive not had any problems
also i guess im unlcear what u mean by teh door locks go off back and forth
do you mean the doors automatic locks lock and unlock at random times ?
the only thiing in relation to the barns that could cause an issue like that is the manual doorlock switch on the inside of the cargo area the wiring harnes or something maybe loose to that switch
Stick
Canada
I've got the barn doors too and prefer them over my last rides deadly failing liftgate. Anyway, look at the brass contacts and pins on the right door jamb. Clean them up, maybe add a little dielectric grease to assist and check it. Could just be getting a false signal due to dirt/corrosion.
Merch619
