OBD2 SCANNER
ikapor
What OBD2 scanner do you all recommend for a 2021 Yukon. I would just use it to clear random DTC that pop here and there and also to do regular services on my car and be able to reset oil, break life etc.
Welcome to the Forum from NH.
Pics of the truck, please.
If you are considering the purchase of a scanner, I strongly recommend that you get yourself a quality bi-directional scanner to add to your tool box. Then, you will be able to read ALL trouble codes, along with a brief explanation/pointer to the source of your issue. You can test many of the truck's electronic functions with the scanner, in order to determine the source of an issue. You will also be able to reset/delete trouble codes, after taking corrective action. You will literally save thousands of dollars in diagnostic and repair costs over the life of your truck, and you will most likely recoup the cost of the scanner within 1 year.
Autel is a trusted quality bi-directional scanner, and the one below is still on sale from Prime Days, but that will change shortly.
Sponsored
Autel
MaxiCheck MX808S-TS Scanner: 2025 Same as MX900-TS TS900, US Ver. of MaxiCOM MK808S-TS MK808Z-TS Upgrade of MK808S MK808Z, Top TPMS Programming Tool, 3000+ Active Test, 28+ Service, 11 OS, FCA
4.7 out of 5 stars
68
Limited time deal
Price, product page
$551.65 (Typical price $649.00)
jfoj
You want and probably need more than a single tool. But you probably also do not want to put out a lot of money for a more advanced tool as you will not likely need it and/or manyof the more advanced tools have costly upgrades. Wait to purchase a more advanced tool if and when you need it, that way it will be up to date if and when you need it.
One if the cheapest and best tools going is the OBDFusion App for your phone, $5 for Android and $10 for iProducts. You will need a wireless interface, they are typically around $32 on Amazon. So for under $45 for you will have a decent OBDII tool. You can carry the interface in the car and you will always have an OBDII tool with you while you are on the road.
Veepeak BLE OBDII interface -
Oil Life Reset does not require a special tool on these vehicles. Have not dug into Brake Life Reset.
A reasonably advanced phone App tool that does a lot of thing is this Think Car tool with more advanced OE support for around $120. These Think Car tools/Apps usually allow you to purchase other OE modules for a fairly low prices you can access other more advanced features for other vehicles in your or your families fleet.
You can also get the more advanced version for around $160 that supports CAN FD and many of the newer vehicles
Some people try to go way overboard with scan tools. The issue is with these more complex vehicles many replacement modules need to be coded and often tied to the VIN. While some of the more advanced tools over $1,000 can do this, having access to the most current software that the modules need and the understanding of how to go about programming them is rather time consuming and risky, you often need an expensive subscription to access the OE software or firmware for modules. Usually in these cases it is just best to bite the bullet and take the vehicle to the dealer for this type of repair work.
For under $200 you can have a pretty good set of scan tools that will do almost everything you would need to do on your vehicle.
I
ikapor
I ended up getting a foxwell NT710 bidirectional scanner. Thanks for the replies I wil post how it goes when I need it
jfoj
Keep in mind for most of engine related and drivability issues you're only going to use the ODB2/EOBD portion of the scanner.
Stbentoak
I just bought a XTOOL A30M on a lightning deal from Amazon. Bi directional and supposedly will work for all vehicles I own. Free lifetime software updates. Reviews seem positive. I've wasted money on worse things. If it saves me 1 trip to the dealer.. was well worth it....
Korbin_A
