Not sure if this is Mechanical/Electrical or "USER ERROR"
denalimike
Hello,
I have had issues with the A/C going in and out recently. To start off, when driving for an extended time, I noticed that the A/C would have a faint "watercooler/swampcooler" smell and it would just blow hot air. I took it to a shop I use from time to time and the guy said, it's possible that the water level is low and so he proceeded to fill up the water tank. (Which seemed like it was enough water to make a difference) Well, it fixed the problem or at least I thought it did as the A/C was working. Later I realized that the A/C kicks on and off as I drive in "city traffic" whereas if I am driving on the Highway, it doesn't work at all. If I am parked, even after driving a while and the truck temperature being elevated, it kicks back on as if there's no problem. Anyone familiar with this problem?
Thanks!
Scottydoggs
NJ
got a clutch fan on your truck? it might be shot. grab a couple of them fins and push and pull it, if its moving its bad.
and its normal for the compressor to kick off and on. just like a ac in the house window.
denalimike
denalimike
2005 Yukon SLT I think, not the Denali. AC is digital one, not the mechanical/manual version. New developments. I noticed when slowing down after a drive on the highway with the radio off, I could hear/feel the compressor or something kick in and then the ac started blowing cold again. I understand that the ac may kick on and off but it stays off for a long "fast" drive and i'd hate to pay for a "recharge" if that won't fix it. We are going on a trip soon so any help is appreciated. I am sorry for the delay in replying. Not sure what a clutch fan is.
denalimike
denalimike
found what a fan clutch is. 1 comes with water pump. Don't have issues with overheating so do I assume that the waterpump is fine? (In the event if it's the fan clutch)
Scottydoggs
NJ
this would be a good time to swap to electric fans if the clutch fan is shot. like i said earlier, grab the fan blades and push and pull, if bad you'll feel and see it moving at the base where that large nut is. if it moves its dead. i went through 3 of them. then went with two 16 inch pro comp fans off a fog light switch with a ignition on power source, so they just ran all the time if the truck was running. you'll need a relay per fan too. my ac was never colder after the fan swap. truck ran a degree cooler too.
if you mean fast drive as in you got it floored, the ac compressor turns off when you go wot.
denalimike
denalimike
I meant driving on the hwy. Do I need to take apart to diagnose?
Scottydoggs
NJ
i really cant explain grab the fins and push and pull look and feel for movement side to side, (not spinning it) any clearer.
normal hwy driving the fan should not even be a issue. the air from moving at 50 plus mph is enough to make the ac work really.
denalimike
denalimike
I guess I am confused if you're referring to the fan that cools the engine or the clutch fan. I guess if the ac works while idle, the clutch fan may work though. I can be parked for 20 minutes and ac works just fine. It's frustrating because I dont want to just start buying parts that may not be broken. Thanks for your help.
Off subject but am I the only one seeing a red "X" at the bottom left of some members posts?
denalimike
denalimike
Nope but doubelieve replied but I see nothing. Perhaps he is just following thread.
denalimike
denalimike
I removed my signature pics several weeks ago though.
Scottydoggs
NJ
the engine cooling fan is the clutch fan and is the only large fan on the engine. not sure what part you might be thinking of.
it also cools the ac as well as the coolant.
this vid shows it all. if its free wheeling its also bad.
denalimike
denalimike
May be high pressure switch. Easy fix and only 20 bucks. Will keep you posted. Thank!
M1Gunner
Gainesville, Fl
How does the a/c belt look? And better yet how does the a/c compressor clutch and coil look?
The belt or clutch may be slipping with the higher rpms?
denalimike
denalimike
So I changed the High Pressure Switch and it "kind of" worked. I took a trip that lasted about 2 1/2 hours and as the trip started, the a/c stopped like normal but we stopped at a gas station about 30 minutes in and after we started the truck back up, the AC worked fine the rest of the way. (and it was hot, like 98). Very frustrating but at least it worked for the trip. Now it works as it did before but I've noticed if the trip is more than 30 minutes, then the AC kicks back in. (or if driving surface streets)
Skiroy56
