Noobie with an Auto Ride & lift ???
friscokidd
Hola, this is my first post on here and i have some questions for you guys.
I have a 03 "hoe" LT w/ autoride and was looking to maybe do the key & spacer lift (2"-3" in front and 2" spacers in rear) but i dont really want to get rid of the air shocks due to the fact that i tow stuff and i like the smooth-ish ride.
is there a way to do this lift and KEEP the factory air shocks? Or is that not possible?
It is possible!!!! you can do coil spacers like every other... I'm working on the same thing with my YD. I'm looking for sway extensions still haven't looked real hard though... i did found some 3" shock brackets threw skyjacker hints y I need sway extensions. But they cost more than the keys and spacers lol... As for the ride height rods the front ones are longer and I'm going to put them on the back and just adjust it back to we're needed... And installing bilstein 5100s in the front (my fronts need changed) that will leave off the extensions up front and ill bypass the front ride control with that resistor mod.
When I get some real money I'm doing the super lift 6" that allows you to retain the airride and it installs the dual shocks up front. It also retains factory steering angles and keeps the CVs at factory angles.. So you don't blow out your CVs like 3" keys will do if you crank them all the way.
lfh2indiana
