No spark, no fuel, no start but will crank 95 2 door hoe, 5.7l, 4WD
dkknaebel
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
Definitely have to replace that pigtail. After starting up and driving great yesterday, same thing as before happened today. So the hubby is going to get that pigtail swapped this evening and we should be in business.
dkknaebel
dkknaebel
St. Petersburg, FL
Ok, so this is what seems to have cured the problem. Put back in my ICM from my 95 distributor and my 95 distributor (all of my donor stuff is a 94 5.7L tbi). The hubby changed out the 4 wire connector that goes to the ICM with the donor from the 94 harness. Truck fires right up. Runs like crap. I'm thinking the distributor got bumped enough to throw off the timing just a bit. It idles somewhat rough and when driving the truck hiccups and bogs. I'm going to have him check the timing again tonight to see if it is just a little bit out and go from there. But, I drove in today and it was great to not be dropped off at work.
Buzarr
