No brake light(lt,rt or top)no turn or hazard signals
bigblackhoe
No brake lights right, left or top..No hazards or turn signals..
I do have parking lights..
All the fuses are good..I checked every fuse I found!..Underhood, Dash end..etc.
All bulbs are good...
They worked fine one minute..then didn't...
Any help is appreciated..
[/B]
TigerEyz3
Slow and Steady
TN
If I was a betting man, I'd say you need a new switch (it's a single assembly containing: the cruise control, hazard, turn signal, and wiper controls).
I had something very similar happen to me... no hazards, no brake lights (top worked, but left/right brake lights didn't). After replacing the control assembly everything worked again.
bigblackhoe
bigblackhoe
The Brake Switch? On the actuator rod going to the booster? I've just crawled out of a psition that I didn't know any man could get into to look at that...I can't see it but I can feel it and there is no way to get anything in there to remove the "clip"..
Do you have to remove the steering column or what?
---------- Post added at 03:53 PM ---------- Previous post was at 03:43 PM ----------
Wait...you're talking about the wand on the column aren't you?
I also just took my meter to check the fuse block for power on all systems..everything came up to 11.5 to 12 on the block..
bigblackhoe
bigblackhoe
I went through my fuse blocks..under hood and end of the dash.
All the circuits came back 11.5 to 12 volts..
I spoke to a Chevy Service writer and he says that I need to replace the Brake Switch and the Multi function Switch...
Does this sound right to you guys?
The MFS is pretty pricey..
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if power supllies are good and the flasher unit is known to be working and not even the hazards come on the the MFs assembly is the issue. it does not go thru the stop switch to run hazards. it draws directly from the battery to the mfs then flasher and back into the mfs to the light bulbs.
180124180
180124182
bigblackhoe
bigblackhoe
Thanks Comet...
Both switches (brake and mf) were going out before this happened..
I was having to bypass the brake to get it out of park and the wipers were acting crazy as hell...I guess the use of the hazards while towing a tuner honda drove it all over the edge..
I ordered a mfs today and will be picking up a brake switch tomorrow..
TigerEyz3
Slow and Steady
TN
Wiper control boards are easy and pretty cheap to replace as well. One screw to remove the cover, remove the old, install the new, replace the cover, voila!!! :D
nico
Nimes FRANCE
Hello has all
If you can put a photo of the switch, I have the meme breakdown, stop lights do not walk(work) any more
bigblackhoe
bigblackhoe
Gentlemen,
Changed out the MFS and the Brake Switch...
All is back to normal!
Found the MFS at a place online..Sandmans Auto Parts
A gentleman by the name of Mark Sandburg owns it. He is out of
Wisconsin..a good guy!
Got the MFS shipped to my door for...44.00!!!
I'm tickled and my Big Black Hoe is back in order!
Drewphil
