NNBS Tahoe 4/6 lowering parts
red02chevy
Lubbock
Purchased all these parts and mocked everything up on the customers Tahoe. After I sent everything out to powdercoat the owner decided he didn't want the parts installed. Everything is new besides mock up. All has fresh glossly black powdercoat. The spindles and coil relocators will fit 07+ NNBS. The rear coils will fit 99-current Tahoes/Suburbans/Escalades/Yukons etc.
*If you're local to Lubbock I can install all the parts for an additional fee*
McGaughys 07+ 2" drop spindles $250 shipped
McGaughys adjustable coil relocators (non autoride) $100 shipped
Belltech trail blazer coils cut for 6" drop, AirLift helper bags with lines & Belltech 8510 shocks $225 shipped
With all these parts installed on a Tahoe it will roughly sit like this.
B.G.
THis may sound stupid, but does there need to be some control module to control the helper bags? Also, could the shock relocators be ran with belltech spindles. I already have a belltech 2/4 but I want to go another 1 to 2 up front and another 1 in the rear. Are you willing to just sell the parts that I need separately? Thanks
R
red02chevy
Lubbock
No these helper bags use a schrader valve to fill them, just like you air up your tires. You can add a compressor, valves and tank but it's not really needed.
Yes you can use the coil relocators with the Belltech spindles.
Are you interested in the helper bags and coil relocators??
B.G.
Ok, good to here.. With the coil relocators, I am assuming they utilize stock shocks? Is there any advantage to these over adding belltech drop shocks instad (up front)?
R
red02chevy
Lubbock
Yes the relocators use the factory shock and spring. Personally I think they ride better then the belltech shocks. Plus you keep the "factory" ride with these.
Sierkonblazer
So will the spindles by themselves drop the front only 2"? Are those all thats need to drop the front?
1st tahoe
