Newly lifted tahoe
scottcully
California
6-8 inch bulletproof suspension lift. 2 crave NX1 18x9 wheels, 35x12.5 in Toyo open country MT tires. 4:56 gears, dual resovoir fox shocks
scottcully
scottcully
California
I'll get more pics. Also I am going to add 1.5 inch coil spacer and lift keys to get a little higher so the tires won't rub.
jdpber
GOLD MEMBER
The America
What upper control arm are you running? Take more of the dual Rez setup. Been thinking about a set on mine.
Copy cat with lifted hoe. Now I will lower mine and lay frame
scottcully
scottcully
California
Thanks, I was expecting it to sit higher. Right now it sits at 43.5 inches all around. Measured at the fenders. When it's on a slope the front is about a half inch higher.
yates ™
Resident Apple hater
Iowa
To me it looks pretty stuffed to be at the 8" max with 35s.
This picture looks like you have plenty of room on the UCA.
image-jpeg.56376
What do your CV angles look like?
TheAutumnWind
image-jpeg.56376
There does appear to be room to crank it up
Johnnyboy677
