New guy looking for some suggestions!
s2kstephen
NoVa
I just bought a 2004 Tahoe about a year ago and I really love the truck. I come from a import tuner background, but the domestic trucks are new to me.
I just rolled over 70k today, and am looking to get some suggestions for me to do some routine maintenance.
Here's what I'm looking for:
Fluids (tranny,diffs,PS, etc...). Looking for product name and viscosity.
Tranny reinforcement (just looking for crisper shifts, not for power upgrades)
SS brake lines, pads, and fluids
Anything else I should look out for down the road? Any preventive mods you suggest?
Thanks for your time and advice in advance!
-S
dwmmatt23
central valley cali
just keep up on your basic maintenance and youll be good for awhile. switch over to mobil 1 fluid and check your diffs to see how they are. spend $20 and get the vette servo for the tranny to firm up your 1-2 shift. best mods to do are cai (get the dry brute force), exhaust, vette servo and bb tune. then your good to go
puckhead
CO
What dw said. If you want you can switch over to electric fans, might already have them as your an 04, cant remember. And if you are running some good electronics the Big 3 upgrade is always good too
ecordell
CordellDesigns.com
Merica
IIRC the 04s do NOT have electric fans, I believe it started in 05
dwmmatt23
central valley cali
and i would probably do a radiator flush, i know it says 100k but im alil leary of the dexcool stuff. its fine to stay with the dexcool stuff but i personally would change it out or if your going to keep it flush it with new dexcool every 50k. ive just heard to many stories and am pretty **** with my maintenance
blueflamed03
Oklahoma
basic check, tranny fluid and filter, oil, radiator flush, rearend, etc.
If at 70K, have dealer run VIN, see if stepper motors has been replaced on yours. Recall was good to 70K.
S
s2kstephen
NoVa
blueflame: stepper motor? What is that?
Sounds like just flushing and replacing the fluids with OEM, corvette servo, e-fans and I'm good to go.
Thanks guys!
kickitandholdit
GA
use valvoleen oil its the best out there right now my friend is an ASE master certified tech and he wouldnt use anything different, they are guaranteeing motors to pass 250,000 miles i think it was, and also research this stuff called Zmax its amazing good! it does everything the box says and you seriously will notice a big difference with it also manny people swear by lucas oil treatment that replaces a qt of oil i personally use all these! and my motor runs incredible it cranks so easy and it amazes many people. it runs so quiet and smooth you can hear the fuel injectors working and thats it. these simple changes are probably the best bang for your buck. the zmax was like 50 bucks though if i remember corectly but well woth it
badtothe bone
western pennsylvania
Anyone that substitutes a good regular maintainence schedule for those miracle cure additives that they hawk on television is only kidding themselves.
There is no one magic bullet brand of oil or additive that can be added to the engine, transmission, rear end, or gas tank that is going to make up for a poorly maintained vehicle.
Look at it like this. If a fuel injection cleaner says all you have to do is pour it into the tank and it will clean your fuel injectors, what would prevent it from picking up all the sludge and dirt off the bottom the tank, out of the fuel filter and out of the fuel lines and running it through the fuel rail and into the fuel injectors - which would cause more problems then it would solve.
The same is true with oil. You want to use the best oil for the application.
At times I will use Pennzoil 5w30 in the winter and 10W40 in the summer.
I change my oil every 3,000 miles and the oil is usually dirty when I change it.
The purpose of the oil is to carry away all the dirt and the sludge and the carbon deposits and move all that crap into the oil filter. The oil filter by the way is over engineered to last 15,000 miles. I always try to substitute the stock oil filter for one that is longer then the stock unit that holds more oil.
I also substitute a bypass oil filter when the mileage gets higher because that not only traps more crud in the filter, it also holds some back pressure against the engine when you shut it off to promote more oil pressure sooner when you start it up when the engine is cold. So in your case, changing the motor oil often and using a high mileage oil filter is a good thing.
I would also change the spark plugs if you have not done it already and I would change the fluid in the transfercase and also the fluid and filter in the automatic transmission. I would forget about performance upgrades and all the crap and stick to the basic's. There is no shift kits anymore, that stuff is all done with power tuners or a Tech II.
Change the fluids in both axles and inspect things like the drive shafts and the universals and the seals on the ends of the axles. Now is the time to repair them while they are leaking and not wait until a bearing failure to do so.
Take apart the disc brake caliper mounts and clean all surfaces and lubricate the pins on the rear mounts and replace any seals that are torn or wore out.
Replace worn rotors and brake pads as necessary to maintain good brakes.
Lubricate all moving parts. That includes door hardware and seat tracks and hinges.
kickitandholdit
GA
yea changing fluids on time is the most important thing and if you drive harder than normal you need to change fluids a bit earlier. and steer clear of the "fixit" additives they can really screw you truck up but there are some that are great like lucas, sea foam, Zmax. you just need to be real cautious with different kinds allot of them are sales gimmicks. just post a thread and ask before you try something.
johnsonwillie199
