wjburken
That's awesome! This is the first thing of 2020 to restore a little of my faith in humanity!
Somehow we knew you'd say something like that!
If you could come up with an adapter for the transfer case, I would think it should work.Wonder if they would work with AWD/4WD applications.
I was thinking you could just swap the tail of the 4l60 over but iirc the output shaft on the AWD/4WD is different (shorter or longer) than the 2WD trans.If you could come up with an adapter for the transfer case, I would think it should work.
I think the 2WD is longer.I was thinking you could just swap the tail of the 4l60 over but iirc the output shaft on the AWD/4WD is different (shorter or longer) than the 2WD trans.
