I have a 2002 Tahoe in which I installed a '02 Escalade Cluster .. evertthing was working perfectly until recently .. at first, the digital (gears and mileage) part of the cluster would flash on and off, then off completely, if I tap the cluster it MAY come back on .. now for some reason, the Trans Temp, Tach, Miles, Gas and Temp gauges are not working .. if I moved the plug around at the top of the cluster, it would flash working, then stop .. if was able to get it to stay on, hit a bump in the road and gone again.
I found that the main connector to the cluster has a broken locking clip, which is making one whole side of the plug somewhat loose.
So, question I have and I'm unable to find .. can someone please find me a PART NUMBER for that connector .. now again, this is the MAIN Cluster connector at the top of the cluster.
Thanks you.
Thanks you.
