need shock options
My1yukon
So I bought a cheap key and block lift off of eBay. Supposed to be 4 inch lift. And I need to get longer shocks. Anyone have any cheap options? I found a set of rough countries for like 189$. Anyone find anything cheaper?
it's a 95 yukon slt 4x4
and will I need longer sway bar links? Or will the factory ones work?
Jerky Arm Ape
North East Louisiana
Rough country is about as cheap as you can get.
Normally yes you would need longer sway bar links.
Hope this isn't for a daily driver.
TheAutumnWind
4" on keys? You'll have no droop, and it will ride like poop.
My1yukon
My1yukon
yeah shes my daily and i figured it would ride bad.. i might mock up some 3 inch blocks.. gonna see how it goes once i get the shocks ordered.. and i got it so cheap it doesnt really matter. i have a nice car that sits in the garage..
My1yukon
My1yukon
they are 1-3 inch keys and 4 inch blocks like i said i will probably make some 3 inchers
Jerky Arm Ape
Mine had 3" blocks, leveled stance and 4" lift shocks in the rear.
I rebuilt my suspension and steering system with Moog chassis parts and precision wheel hub assemblies.
a little over 9,000 miles later and it was no longer safe to drive, could not be aligned either.
had to do it all over again so I took that bullsh*t lift off.
My1yukon
My1yukon
if it gets that bad ill make it a mud beater i only drive like 20 miles per day
JPeter
