Need new shocks - best recommendations
The KYB Gas-A-Just shocks (KG5040) I got for the fronts on my ZW7 suspension are great. The performance improvement in my truck is very noticeable compared to the OE shocks that went 106K miles, especially over speed bumps and when I pull into the driveway. Faster recovery.
My Nivomats had around 250-260k on them when I took them off, and they were still working great. I couldn't even compress them by hand.
Askold_JB
Does that mean that the Autoride springs are the same as the Premium Smooth Ride springs?
Sorry for confusing. I thought TS has Z55 - Autoride truck.
If I get everything right - ZW7 is more like Z71, but Z71 Moog analog is 81069, and ZW7 is 81071. They are pretty same sets, but 81069 is 1" higher.
texas1
I got the Bilstein 4600's, been riding on them for about 2 weeks now. The driving experience is so much better. The old worn out shocks made the truck feel like it was going to fall off the road.
U
UmmScott
Omaha
Hey guys. Long time no talk! Man its been a crazy year so far.
To recap... so if I have this right.
With my RPO code ZW7 that had self leveling rear suspension.
I need to make sure I have the shorter rear springs if i replace with regular shocks of my choice correct?
I dont want to keep the factory self leveling spring with aftermarket shocks yes?
Correct. Guys who swap from the ZW7 seem to go to Z71 rear springs. ZW7 rear springs are too soft for standard shocks. I made that mistake. The rear swayed side to side at highway speeds. Pretty scary.
U
UmmScott
Omaha
Hey guys. Decided to go with the Bilsteins all around.
Wow. What a difference for sure!
Pretty impressed
Pretty impressed
Thank you for getting back to the folks on the Forum here regarding your purchase decision. It is great to read that you are happy with your Bilsteins.
Long Island, NY
Hey guys i have a question my 03 denali the compressor finally gave out and i found out the hard way when i had to tow my trailer with another car on it the back sat pretty low. I wanted to ask if the Bilsteins are good replacements for stock height and lowering cause I'm not sure yet if I'm gonna drop her but i know i don't wanna stay with the autoride at this point.
Colby_e32
The 4600 bilstein will give a great ride, lowered, or stock. The 5100's are more of an offroad/heavy duty shock.
I will suggest if you do lower your truck and use bilstein 4600's pickup a set of shock extenders, as when you lower them, you will not have the correct travel needed.
hope this helps. thanks
If you get rid of the autoride, then you will need to change the rear springs to a non-autoride spec, as the autoride springs are softer, and you won't have the air to assist them.
thanks. You replaced the rear with the nivomats?
No, at 1st I used KYB Excels with the Nivomat springs. The stock springs were too soft and the KYB Excels are garbage. I had them on maybe a month, then literally threw them in the garbage. Bought some lowering springs and got some Bilstein 4600s from a fellow member. Rides way better.
03X2
South of Atlanta Ga
Thanks for the info. I looked through your build, incredible, especially the 6.0 swap!! Ive been giving some thought to lowering my ‘03 Tahoe 2WD that has the Nivomats. You mentioned purchasing an ‘inexpensive’, but couldn’t find what you used……
Thanks!
I bought a lowering setup from Crownsuspension.com. It came with lowering keys instead of spindles. It's not the best kit out there but I was on a budget, and it rides fine for me. Is this what you're referring to specifically? Or are you asking about shocks?
03X2
South of Atlanta Ga
03X2
South of Atlanta Ga
Thanks!
Both actually, also, did you do the install yourself?
03X2
South of Atlanta Ga
Thanks!
did you use the 2”, 3”, or 4” lowering kit?
The 1st cheap shocks I bought were the KYB Excels. I used those with the original Nivomat springs--which are way too soft for non Nivomat shocks. At highway speeds the ride was actually scary. The back end would sway side to side. I wasn't the only one that had issues with those KYBs. Complete garbage! Don't waste your money. Iirc I went with the 2/3" drop from crownsuspension.com. came with rear lowering springs, rear shock relocation brackets and front keys. I had someone install it for me, but if your handy you could do it yourself, not very hard at all. You will need a special tool for the front keys iirc. It's been a few years and my memory is a little fuzzy, but it's pretty simple to do. Imo the best/budget shocks to use on these rigs are the Bilstein 4600s. Worth the money. IMAG1300001_1541794293671_001.jpg
My rear setup now. You can see the rear shock extension bracket that comes with the lowering kit.
You can also see the rear Hellwig adjustable sway bar.
john1989
