Need help with wiring
ivin74
05 NBS Nali
Htown, Texas
I believe there is no female pigtail to that connector. The actual female connector is attached to oem horn.
wjburken
Eastern Iowa
SnowDrifter
SnowDrifter
Sasquatch Country
Close but no cigar.
The spacing on the horn connector is a bit wider - there's a channel down the middle separating the pins
Man this is a tough one to track down
wjburken
Eastern Iowa
Close but no cigar.
Interesting. That is the connector shown with that harness listed on Amazon. Do you have a picture of you horn connection?
SnowDrifter
SnowDrifter
Sasquatch Country
SnowDrifter
SnowDrifter
Sasquatch Country
I suppose now the question becomes if I can get them stand alone or if I need to get the damn kit and bin 90 percent of the stuff in there lol
Your Google fu seems a hell of a lot better than mine. I was coming up dry; can you find anything?
wjburken
Eastern Iowa
I’ll see what I can find.
DougAMiller
Colorado
SnowDrifter
SnowDrifter
Sasquatch Country
Ugh
So I looked through thwt connector guide a couple times. Couldn't find it
Went to order that kit, out of stock where I look.
Poked at Google for honestly longer than I should, can't find the proper male end anywhere.
Kind of at a loss at this point. Seems to be a nonstandard or custom connector. I really reallllyyyyyy didn't want to cut the wiring. But unless anyone else has any resources or ideas, I'm rapidly approaching that point.
I understand and appreciate not wanting to cut wiring. But, with as much time and effort that you've invested into saving this one connection style so far, is it still worth it? Go to the salvage yard and snip some male and female Weather Pack connectors with convenient lengths of wires attached of whatever gauge you need, solder and heat shrink them to your harness and it'd be a done deal.
JPeter
