Need help understanding how (REAR HELPER BAG KIT) can help my 5" rear drop?
BLKCaddy
Houston, Texas
Im about the lower my rear 5" and i was wondering if the rear helper bag kit would help with the ride.
Physh1
Depends...I have zero ride complaints on my 5" rear drop with TB spring. Ride is comfortable yet firm when it needs to be. A helper bag kit always needs to have a few psi in it & I believe when inflated a little more you'll start to lift the rear.
It sounds like you're assuming a 5" rear drop will ride like crap.
More info...what spring & shock combo will you be running? Shock relocators? Trailing arm kit?
Cameron
BLKCaddy
BLKCaddy
Houston, Texas
I have the but not installed yet "http://www.stylintrucks.com/part.aspx?category%7ccategory_root%7c-30=Suspension&category%7ccat_-30%7c373=Lowering+Parts&canned_results_trigger=&partfamilyid=6222&partid=594729 and theses shocks http://www.stylintrucks.com/parts.aspx?category%7ccategory_root%7c-30=Suspension&category%7ccat_-30%7c237=Shocks&canned_results_trigger=&partfamilyid=1882"
What are your thoughts and if its going to be a issue with a bad ride or is it fine or would you swap something for another?
NORCAL SS
SUV SUSPENSION GURU
honestly return that kit and get this
http://www.tbssowners.com/store/index.php?act=viewProd&productId=107
and
http://www.tbssowners.com/store/index.php?act=viewProd&productId=98
and I hae the rear djm shocks
total $450 shipped from me to you (rear hardware kit/springs/shocks and will ride much better than that combo which is proven here many times already.
heres one happy customer
http://www.tahoeyukonforum.com/forum/showthread.php?t=22616
and another
http://www.tahoeyukonforum.com/forum/showthread.php?t=22048
Physh1
I don't think you'll have a bad ride but everyone has different feelings about what is good, ok, best, & bad. A lot of guys here, including myself, ordered full drops from NorCalSS. I'm absolutely happy with my DJM/BellTech setup.
I am running the DJM shocks up front (stiffer) & the BellTech in the rear (softer)...I think it gives a very even ride. I don't think you'll have a bad ride going with the kit you linked to but I don't have any experience with that coil personally. I don't know its characteristics...
Cameron
NORCAL SS
SUV SUSPENSION GURU
ive switched them out here locally and guys have done the same on the board. the tb spring sat lower and gave a nicer ride.
Since the kit is new id just return it and I think you will even save money getting the set up I have since its cheaper than what stylinconcepts has it for
dizhai
