Need help finding body mount perch/cups
76Nick
Okay so unfortunately I'm not happy with the 4-in suspension lift that I did and rather than investing in a whole new suspension lift I figured I would do an inch and a half body lift. So when I do that I'm going to change out all of the bushings for polyurethane ones but my problem is it looks like a number of my cups/perches where the bushings seat have a little rot. My question is what are they exactly called because I can't find them online for some reason.. I have no problem finding the body mount brackets that are welded to the frame but not the cups that are on the body. Also are those cups welded on or held on by the bolt? Thanks guys!
Trey Hardy
Body mount bushings
Look up energy suspension or S&B they are the two who makes them
Their pricey but is yours are shot they should make for a smoother ride beings the new bushings are silicone/polyurethane vs the old hard rubber
Trey Hardy
I don’t know if you can get the 1.5” body lift with bumper relocation brackets or not I’d have to go look. If not I’d suggest to just get the 3” ones so you can get the front and rear bumper back into the factory location the trim and steps on the rocket panel will cover most of the frame so it won’t be too bad
TexasTaz
