Need help Bazooka tubes or Box
sebby55
Brooklyn NY
Have not found a thread about bazooka tubes is everyone using box's?Any opinion on bazooka tubes would be helpful thanks
TnTahoe
TN
bazooka tubes have gone by the wayside
mrtrill
ATL
bazooka tubes r :supergay:
pre fab boxes r :party33:
A well built to specs box is :rocking:
sebby55
sebby55
Brooklyn NY
OK tubes are out as far as box's bandpass? ported? sealed?Im not looking for bass that u can feel or hear down the block just something to make the seats rumble.Thanks for the feed back.By the way the amp I have is 600rms @ 2ohms/300 rms @ 4ohms
TnTahoe
TN
if thats all you are looking for then i would recommend a sealed enclosure
sebby55
sebby55
Brooklyn NY
Thanks.Any off the shelf sealed box you can recommend?just got pioneer deh7200 hd radio any opinions on the radio?
Huck
Whut Thee Huck?!
San Diego
What type of subs? What size?
You can get a decent priced custom box for cheap. Actually...
I have a custom box for sale. For two Tens. Downfire, behind third row.
sebby55
sebby55
Brooklyn NY
@Huck thats to big I also dont have a third row I have a 02 Z71 w/factory subwoofer
I'm thinking about replacing the stock 8inch woofer with a Kicker 10cvt84.Not sure if it will fit in that factory box.Any idea if this will fit?
Thanks again for the feedback
Image gallery
Item # 10cvt84 Kicker CVT84 (10CVT84)
8" Single 4 ohm Shallow-Mount Comp VT Series Subwoofer (CVT8-4)
8" CompVT Subwoofer • Single 4 Ohm • Shallow Mount • 400 Watts Max • 200 Watts RMS • Rigid SoloKon Cone • Ribbed Santoprene Surround • Shallow Steel Basket • Four-Layer Voice Coil • Includes Steel Mounting Plate
sebby55
sebby55
Brooklyn NY
I made up my mind (sort of)
Kicker TCVT122 (10TCVT122)Compact Single 12" 2 ohm Comp VT
Has anyone used this box before?how is the bass?also i read that you should use a amp 75-90% of the subwoofer rms. I also read that you should use a amp with more rms (ex.100rms sub/150rms amp)which is the correct info?
01yukonslt
need more deebeeeez!
Spokane, WA
you always want the amp to have the same if not more power than the sub can handle in order to send it a good clean signal. it doesnt necessarily hurt the sub to run it at less power but many mistake the gain knob for a volume knob and will send a clipped signal to the sub resulting in failure. if you have a 300 watt sub and 300 watt amp you should be ok though. not sure on the ratings on that cvt but in a sealed enclosure you can run a little bit more power without hurting anything.
sebby55
sebby55
Brooklyn NY
Thank u everyone for the input on this topic.I feel pretty comfortable on picking out some more music now.
DIY_DAD
So Cal
bazooka's arent worth the $ they are very poor quality subwoofers with low powered amp, you can get pre fab boxes loaded with subs and sometimes even an amp for dirt cheap nowadays, check http://www.crutchfield.com they always got scorchin deals and are extremely reputable, i get all my stuff from them <5 stars>
vsaravia
