GranPrix
- Joined
- Sep 10, 2017
- Posts
- 741
- Reaction score
- 510
Has anyone installed the Belltech 25004 adjustable front struts on their PPV?
I need to know how many rings were used under the spring perch for ride height. Belltech instructions are only for base model ride heights not PPVs
I get all that, the problem is the spacer table on BT's instructions are for the base model that sits a bit higher than the PPVs. So I can't really follow that table as far as the drop I want. I'm looking to drop 1 inch up front. So as far as that table goes I think I'm going to use 3 rings instead of 2 if I'm thinking this out correctly...The stock drop is accomplished with shorter coils. Specs for the 25004 say 0"-3" drop in 1/2" increments. So, according to this, if you don't want any drop from the struts, you'd use all the rings, essentially making it like a stock replacement strut. You can measure the distance from the stock strut's lower mount (the cross bar) to the perch that the coil sits on. Use whatever number of rings puts the perch on the BT strut at the same height from the cross bar.
Page 4, far right of chart says to use 6 rings:
I would compare the perch on both side by side myself but I'm not doing the work and I won't be there when the mechanic is doing the work. I'm giving him the struts with the rings already set.
