Nearing 155K Miles on my '04 Denali - Things to keep in mind?
996
Hi All!
As the title states, I am nearing 155K miles on my '04 Yukon Denali. Great truck. What things should I look out for / replace for preventative maintenance? Fluid changes? Bushings? Etc...
Had my transmission rebuilt 10K miles ago. Running smooth.
Thanks a bunch!
Z28TWITCH
Do it all...haha...no seriously...all of it...coolant flush...oil change...plugs and wires...brake system flush...new serp belt and a/c belt...transmission mount check....u joint check...air filter...check the rubber brake hoses for swelling/cracking...shocks...check torsion bars for sagging...same for rear springs...I could go on forever...just do the basics unless something is visibly needing attention...as far as replacing a trans at 140k....what did you do/not do? hahahha
abishoff
Rebuild the front diff. I'm sure it's already louder than it should be.
curbud
