Nasty smell
rockymt21
wing addict
from the slums of shaolin
I've got a nasty musty smell coming from the heat/ac vents. I used the heat the other night and the car reeked like an old sweaty gym bag. I've done some searching on how to fix this and what I have found is people having to buy a deodorizing kit at the dealership. I was wondering if there was any way I could try to tackle this myself without spending a lot of money before I go and get it fixed professionally.
Modded
That Guy
ooks like you never saw my thread in the 07 Tech section?
blueflamed03
Oklahoma
To remove the moldy odor from the A/C, get a can of Lysol. With the truck running, turn on the HVAC control to high, outside air. Open the hood and spray the Lysol into the vent that brings in the outside air. It is located in the cowl area; you will know if you are getting it in the vent if you smell Lysol in the cab. (The smell of lysol will go away after a half hour or so.) The mold odor will be gone along with the lysol smell.
afpj
Also consider removing (or if dirty, changing) the cabin filters, and spray Lysol into that intake area. I've had alot of leaves and crap accumulate there.
tahoe7689
Oreillys sells a special deodorizing spray that is supposed to do the same thing as the lysol mentioned above. I have used it and it took care of the smell
Modded
That Guy
I can give you more feedback on Friday when my Klima Cleaner gets here!
rockymt21
rockymt21
wing addict
Maybe I'll give one of those sprays a try. My only question is was it a permanent fix? Did the smell come back, or was there still a trace of the smell when using the a/c or heat?
blueflamed03
Oklahoma
it's from condensation in the HVAC system, or the water not draining properly if it comes back.
varminpoolteam
