Mystery leak?
Symba_The_Lyon
So there is a leak under my passenger side floor board it look like it is coming out of the blower motor?, every time it rains there is a small puddle in the floor board I have taken three pictures so you know where i am talking bought, Anyone know how to fix this? and the cabin fitter is dry as a bone when it happens x,x
Danzigman
Galveston, TX
Do you have a factory sunroof? If so check the drains in the front corners. I had a simular leak on the drivers side.
---------- Post added at 02:27 PM ---------- Previous post was at 02:27 PM ----------
Oh, sorry I just noticed you have an OBS. They may be different.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I am thinking the cowl screws need to be removed and some sealant put on them. Just can't recall where it was brought up. I think it was GM.
Symba_The_Lyon
Symba_The_Lyon
sealing up the screws might be a going way to start, I did just get my windshield replaced recently and i did not have the problem be for that :happy160:
_Dylan_
STAY FROSTY
remove wipers
remove cowl
clean
replace cowl
replace screws and seal them with silicone
it's a very common problem
95escahoe
Common issue like others said, try what they mentioned, if not then you need to remove that panel on the cowl and ré seal it
Sent from my HTC One X using Tapatalk 2
2DR4EVR
Texas
You replace the windshield recently? I had the same problem. Water would drip from the blower area and pool under the running board where the passenger door met the frame. Carpet would get all flooded out in the rain.
Tracked it down to the upper portion of the windshield where water was running down and around the seals. Had it resealed and no problems since.
This was do to a ****** install on a windshield.
Symba_The_Lyon
Symba_The_Lyon
So it was the cowl letting in the water in the did not replace the screw back on the passenger side so i just found another identical screw lubed it up with silicone it it fix the problem :beer:
04SS99Denali
NY
welcome to the OBS world haha
on NBS trucks this is usually from a clogged A/C drain tube or leaky sunroof - door sills. but on a obs id check the windshield
blatta1999
I am having a similar issue but the leak is in both front floorboard areas. I looked at the cowl and there are a few issues. The rubber seal at the top of the cowl is missing and the mounting screws on both corners are there but the cowl is cracked and loose, more on the driver side. I'm assuming this could be my problem, but why would this allow water to the floorboard? And what is the easiest way to get the wipers off? I'm assuming mine have never been off so I don't want to mess up the spline but they are tight on there. Any help is appreciated!
Yizzo88
