Mystery Device Found in Engine Bay
rgpinder
I found this device today in my engine bay while doing another project and it appears to have been left there from an oil change perhaps? Can anyone tell me what this does?
I believe it's an air filter monitor. When connected between the filter and intake, a dirty filter will restrict airflow and the increased vacuum will pull a spring-loaded indicator down showing that it is time to replace the filter.
This^^^^. It pops into a grommet on your air filter housing. It lets you know if the filter needs to be replaced. Look for an empty hole with a rubber grommet in it on your air box.
mountie
It goes into the side area of the air filter box. The red 'line' should be in the green area when installed, and after you drove for a little while, to get the gauge to "do it's thing"....
( "..... youngsters ..." )........ You meanies !!! :baby:
rick3645
