My 2010 PPV
A
AV2010PPV
Decided to do a brake flush since I got myself a Motive bleeder for my other cars. I can’t believe how dirty the old fluid was. So glad I decide to flush it.
A
AV2010PPV
In 165,000 miles I don’t think the engine was ever detailed. Rightfully so for a previous prison warden car. There’s a first for everything. Before and after pictures included:
Sparksalot
Bastrop County, Texas
Mine next? I did the Airaid, so it’s still fairly clean.
A
AV2010PPV
Took the PPV on a long road trip to Angel Fire, NM. Car drove and performed really well even in zero degree weather. One of the TMPS sensors did not appreciate the cold. Luckily I had spares and a reset tool. First year of ownership I put on almost exactly 20k (150k-170k) trouble free miles.
waveryd
IL
Truck looks good! Jealous of that push bar! I have been looking for one for mine but no luck yet.
A
AV2010PPV
Well saw that my radiator had a tiny leak so decided to replace it. Flushed out the system several times with fresh coolant. While I was in there I put on a new serpentine belt and air filter. Added some power steering fluid as well.
A
AV2010PPV
Clean up
A
AV2010PPV
Then I decided to add some red/blue leds near the front visor and rear window. Added some ditch lights for the front and some additional led brake lights for the rear:
A
AV2010PPV
Lastly I decided to replace a worn down door handle and wash the car. This Tahoe is getting all the love.
A
AV2010PPV
I finally decided to swap my oem Goodyear tires to something with a larger sidewall (265/70/17). Got roughly 25k miles out of the Goodyear tires which was impressive. Also decided to install a catchcan just because I was bored as well as super bright LED reverse lights. Adjusted the striker plate on the drivers front and passenger front door to eliminate some wind noise from both door. Also made bought two extra key fobs and programmed them to have backup keys and fobs. Loving the PPV!
A
AV2010PPV
Decided to upholster my steering wheel and change out my front and rear emblems to aluminum ones. Then it was work time.
A
AV2010PPV
I figured with the steering wheel looking nice I’d replace the stalk. The flash to pass never worked since I got the car. Once I replaced with an OEM stalk, everything works as should. Double win!
1948Buickroadie
