My 2008 Esky Project, Pic attached
73TA
You may have already read my post regarding LT headers. Here is the project 2008, 200K miles. Supposed to have a bad lifter, etc. The owner says it actually runs fine, just a valvetrain noise in the engine according to her mechanic. She was told to just replace the engine. Anyway, I got her down to $3200. She has all the records. She told me that she had just put on new air suspension, and claims she spent $3500 on the tires and wheels. She will also give me the stock 22's also.
Going to go with standard LT's, cam, etc. Motor will come out to be torn down for bearings and rings if needed.
Mike
MikeView attachment 264518
Hell of a deal. Has the 6.2 or 6.0?
1BADI5
DMV
Lucky SOB!
Look forward to the build and your findings in regarded to the motor
73TA
Going to pick it up next week. I kinda of feel a little bad about her losing so much money it. But someone had to buy it. I will start a thread when I begin tearing it down.
Mike
73TA
Went to pick it today. When I pulled into the driveway the engine was running, was a little alarmed at first, worried about causing engine damage. The good news is there is no engine noise, no ticking, knocking, nothing. However, it is running on cylinders. Hooked up the scanned to the OBD port. No power to the scanner. Going to check the fuse for the cig lighter tomorrow when it is light out.
Hope that is just a broken valve spring?
Will follow up tomorrow.
Mike
73TA
Got power to the OBD port, #6 misfire. Verified spark to #6, Pulled the valve cover, it wasn't a broken valve spring. Went to use the starter to turn over the engine to check the rocker arm action to see if the cam was wiped and it started just on the driver side cylinders. Will do a compression test next.
91RS
GA
What a deal. I tried to find a “mechanic’s special” and the money they wanted for all of them would have made it more expensive than buying one that wasn’t broken.
Your problem is very likely lifter failure (the hydraulic lifters don’t fail in the same way the AFM lifters do so it isn’t easy to spot visually). My guess is your compression will be fine. Do a running compression test and I bet you’ll have a result.
73TA
91 RS, thanks for info. What do you mean by a "running" compression test. I assume that I would actually start it up and check it will it is running?
Mike
dizhai
