MTX ThunderForm Chevy Tahoe 2007-2010 Custom Sub Box
ddjozone
Just installed this in my tahoe lt today.. Annoying!!! But sounds great. Only got the box. ImageUploadedByTapatalk1352332924.081059.jpg
ImageUploadedByTapatalk1352332950.330672.jpg kicker cvt10 shallow mount.
ddjozone
Had a little kenwood mono amp that was collecting dust to power it.. 200-300 RMS..ImageUploadedByTapatalk1352333187.997913.jpgImageUploadedByTapatalk1352333197.665714.jpg
ddjozone
My console didn't fit perfectly when putting back together... But oh well.
Vince6322
Hey looks good I will be doing same install. how do you like the sound?
ddjozone
Sounds nice. Definitely doesn't shake the truck or anything. But def much much better than stock boss sub.
shundal
NorCal
Looks good! I had the JL Stealthbox in the same spot before and it definitely adds some good bass to the front stage. What exactly didn't fit properly when putting the console back together?
ddjozone
Yeah... The console wouldn't drop to the same level in the front... Like I needed to cut out the space for the cup holder... Or I didn't push the thunderform deep enough under the receiver. Idk
ddjozone
ddjozone
It was actually my fault. There was a factory cable under the thunderbox that was keeping it from being flush with the tahoe floor... I moved it out of the way and its fine now... The thunderbox is sounding better an better as it breaks in :)
shundal
NorCal
Good to know you were able to fixed! Yea the console sub is a great solution for adding good clean bass up front and giving up zero space.
wheatswake
houston texas
the box with the mtx amp already installed sounds good to me, its also nice not have to do an amp install somewhere else.
aggressive
How is everyone securing these to the floor? The instructions say to use a 2 inch screw but that sounds a little sketchy to me...
Keanen55
Keanen55
HOUSTON, TX
I didn't even bother bolting it down. The center console holds in place just fine! :thumbsup:
aggressive
Thanks for the info. I just finished the install with a 600w Comp RT. Sounds amazing!
Shimmy23
WA
Based on the quick read, no one secured this to the floor? Aren't you worried it will somewhat move and eventually start to vibrate/rattle the center console?
Chris9117
I have a 2011 Yukon Denali. Not sure how similar this would be to a 2011.
Question, did you have to take the seats out to install this box? Where did you put your amp for this box? How long did it take you to install this box? This is very good information that was discussed on this board and I will using this to install. thanks
M0rph3us
I found this guy on eBay that sells a complete kit for the center console install. Has anyone used his boxes before? Seems very reasonable considering it comes with the wiring and amp that all fit nicely under the console.
Link here to eBay auction
dizhai
