Motor Oil
easybake
Hey what is your guys opinion on motor oil to use? im about to get an oil change and would like to know.
Cobra
Austin, Tx. area
Agree Royal Purple is suppose to be the shit. If you can afford go for it.
I myself have always used Mobil 1 full syn. 5-30 in my rides..
Max
Mile High
Denver
I get royal purple for cheap through work, runs great and my truck tests stock compression numbers across all 8 cylinders with 100k.
Tribalbreak
WARminster PA
ive been using the mobil 1 syn. 5w30 truck and suv blend... no complaints, might try the royal purple though
IanSLT
Calgary, Alberta Canada
0-30 German Castrol
Look into the 0-30 Castrol full syn. but the key is to look for the bottles that have the red seal crest on the front and on the back of the bottle it will state that it is manufactured in Germany very important. Bob the oil guy as found on the internet (bobtheoilguy.com) has some impressive test results on several of the leading brands, I also own a BMW-540I M sport in which only certain oils are approved and carry the correct SAE shear/stress rating and the German castrol is one of them.
Don't be fooled by the "0" weighting value as noted by the tests it's a very good oil.
Cheers Ian
Travieso
Boooooooost !
Los Skandeles, CA
Mobil 1 full syn. 5-30..here also.. i just did my oil change today and the guy that usually does my oil change recommended me to change my oil grade to 10-30 after 55K miles is this accurate or should i just keep putting Mobil 1 full syn. 5-30 ?
withac
Eastern Idaho
RP. May be spendier but after the first change you can run it longer so the money evens out and you get better protection.
Clemsonbloz
kendall... lol
whatever 5-30 synthetic that is on sale at wally world... this change it's penzoil I think.. think with yer dipstick jimmy
gtbigup01
Columbus, GA
Mobil-1 syn for me and I just picked up 5 qts and a M-1 filter for a special of 29.95 I had to pay regular price for the other QT
cnatalie
St. Louis, Missouri
Although I am not a mech. I have worked in mech shops and dealerships my whole life. That being said, I have heard of engines having dirty oil problems, no oil problems, but never a "cheap" oil problem.
AutoZone's 10w30 has always worked for all 130k on my truck. No complaints yet.
johnsonwillie199
