Motor Mounts
2001 TX Tahoe
I have two friends, both with 6.2L motors under 100,000 miles, that have had to replace their motor mounts. Is this specific to the 6.2L or is it an issues with the 5.3L as well?
GMT800 2005 Tahoe Z71
Navy Supporting Member
A motor mount, made of rubber and steel, is a wear item and will eventually have a need for replacement. It can depend on where the vehicle is driven, temperatures, salt on the roads, how hard the vehicle is driven and the types of driving that is done and of course, the quality of the part. Some mounts have a history of failing prematurely. I have a 2005 with a 5.3 engine and my mounts have been replaced because I like to do things before I have trouble. I do not own a 2015 to 2020 model and therefore I cannot offer an opinion on whether these vehicles have problem mounts. Good luck.
Marky Dissod
Is this specific to the 6.2L or is it an issue with the 5.3L as well?
If two schmekelheads drive with the same gratuitously leadfooted style, assume the 6.2L would have to replace at least one of those motor mounts before the 5.3L, just 'cause the 6.2L is stronger / more powerful.
On the other hand, if the guy with the 5.3L keeps slapping the throttle against the floor whenever possible while the 6.2L is driven gracefully, I bet the 5.3L will need a motor mount replaced first.
When it comes time to replace that motor mount, though, I'd be looking for an upgrade of some kind, being leadfooted and all ...
I'm not knowledgeable on the details of the 15-20 body style, but with the NNBS, Hummer H3 motor mounts were suggested for the 6.2, to increase their life. The 6.2 came with motor mounts that have a fluid in them to reduce engine vibrations in the interior of the truck, and this fluid ultimately escapes.
2001 TX Tahoe
Interesting. I wonder if that makes them more prone to failure, because I have heard that they are a known failure. And to clarify, both cases are 2015-2020.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
I replaced my 2012 Yukon SLE (5.3L) motor mounts at 100k. They were hydraulic and one was leaking, so I replaced both. The hydraulic ones have a lot of problems, so I went with the old rubber/steel ones. No problems after 3.3K miles.
Marky Dissod
I wonder if that makes them more prone to failure?
1stly, every experienced mechanic can guess which motor mount is more likely to fail sooner based on its position.
2ndly, the old rubber & steel motor mounts are more durable and tend to last longer,
precisely because they are NOT trying to hide NVH issues from Aunt Cester or Aunt Teak.
Which ones do you mean? 2500 / 3500 HD pickup truck-type stuff?
Or aftermarket polygraphite?
BG1988
how are the H3 mounts in regards to vibration in the interior? for my 6.0L
fozzi58
North Jersey
Just ordered these. I got the 1/2" lower ones to drop the motor a bit. Should help me in autoX a bit.
I don't know what the motor mounts are for the 6.0, but my guess is that they do not contain fluid, so the conversion would not impact the interior, vibration-wise. Folks currently with a 6.0 and knowledgeable about their motor mounts will chime in.
AdrienR
