Moog 81069
Hunter Linn
Tuscaloosa, Alabama
Hello all,
Has anyone here ran the Moog 81069 rear coil spring? If so, how did you like it? Are there any better options as replacement over stock coil springs?
HiHoeSilver
Away!
Chicago
Hello all,
Tons of info available on this. That's the stock z71 spring. It will net you an 1" of lift over the regular ones (give or take).
akbrener
Baltimore, MD
I have them on my 08. got the inch or so over my factory springs. helped a bit too when loaded up.
73Vetteman
Just a reminder that an affordable and easy way to raise the rear is to use a 1" or 2" spacer under the existing spring. They can even be combined for greater lift. Replacement of springs is not necessary to raise the back. I think I paid $36 for Belltech 2" spacers.
varminpoolteam
