Moog 81069 springs
mikebrawn1
Has anybody installed these springs on their Tahoe? How much lift did you get?
TheAutumnWind
Depends on how worn out your current springs are, and which springs you have currently. Should be less than an inch in the rear.
M
mikebrawn1
I have an ltz with rear air. I know these will be a good bit stiffer just curious if anybody else has installed them.
M
mikebrawn1
I can't seem to find anything in search and nobody is responding. I ordered them anyway and also ordered a set of the monroe ma830s to replace the worn factory rear air shocks. I'll get it all together and see how I like it. I replaced the front struts with a set of the unity quick struts from ebay and it lifted the front end of my tahoe a good bit so it now looks like the rear end is loaded with junk (or atleast a full diaper). I am hoping to remedy that. It's only 3/4 of an inch difference from both wheel wells to the ground.
Post a pic! In kinda saggy too. Will send pics tomorrow after alignment
TheAutumnWind
Interesting that you couldn't find any info on these. They are just moog z71 replacements. Most of the guys installing z71 spring use the moog brand.
M
mikebrawn1
Well I got them installed yesterday. Not too bad of an install. I also installed the monroe ma 830s. I expected it to drive a little differently but it really feels the same. I need to lengthen the rear rods so the air will come on sooner to lift the back but I definitely like it. Will post some pics when this rain stops.
M
mikebrawn1
I haven't had a chance to get pics yet but the fender measurements are 37 1/4" front and 38" rear. I wish I had gotten measurements before but I didn't. I know the rear was 3/4" below the front before rear springs were replaced but I don't know before in front. I didn't expect the struts to lift the front so I didn't think about it.
akbrener
Baltimore, MD
I went with the springs and a pair of Gabriel ProGuard HD shocks ($20 each)
My truck had the ZW7 premium smooth ride, and at 150K miles it was pretty soft. rear measured 37 3/4" at wheel well. Now it is about 39 1/4". We'll see if it settles out.
I have the 2" level up front and it measures around 38-3/4" so finally it actually is level, not nose high.
dizhai
