Missing Rear Air Control
Mikana31
Been lurking for awhile. Great info. Thanks to everyone.
I just bought a 2013 SSV which had been outfitted as a Canine Vehicle. They did a pretty good job of removing all the Ray Allen extra canine goodies, but the one thing I can't find is the rear air control. The center overhead light console is the stock one without the controls. The front center is the jump seat. I am not sure what the connector looks like, but it's MIA. Any ideas for me to be looking for? I don't mind install the controls, I just need to find the harness.
Also, my rear windows will roll up from the driver's door, but not down... just in case someone has dealt with that. :)
Your window switches probably need to have the contacts cleaned, it’s common for them to corrode. Pull them apart and clean the copper contacts on the pcb boards with an eraser or alcohol, reassemble and voila.
M
Mikana31
Theres not a button on your ac panel that says rear?
There is the button but it doesn't engage the rear ac. I thought the button activated the rear ac control, which would be accessible from the middle seat?
you might have to pull the rear passenger side panel off and check to see if the blower motor or resistor is out, there is also a rear module that can fail but I would start by applying 12v to the rear blower motor and work forward from there.
golavaman
