bayareadude84
Just moved to CA and have to SMOG my burban soon
it's a '01 5.3 BTW
Problems
White smoke at times from tail pipe
Slight Misfire
Ran my SCAN and only codes is P0420 bank 1
Already
Replaced all 8 plugs and wires AC/delco
New Gas Cap Stant
Replaced PCV valve Purolator
Replaced both lower o2 sensors Denso
Seafoam the gas in tank
SeaFoam the intake via Brake booster line
Cleaned intake with CFM spray
Many said its a bad cat converter=$$$$,Mechanic I ran into at orileys said its a ignition misfire issue,nothing to do with cat ???????
it's a '01 5.3 BTW
Problems
Slight Misfire
Already
New Gas Cap Stant
