Just00Jake
- Joined
- Jun 27, 2022
- Posts
- 63
- Reaction score
- 41
I have a 2013 Tahoe LS that I've owned for about 8 months. When I bought this Tahoe it had a rough intermittent idle. I put a scanner on it, an inexpensive OBD2 and it said that the O2 sensor at bank 1 sensor 2 had a problem, so I changed it. Shortly there after I got a code that there was an issue with bank 2 sensor 2, I was getting a code saying it was reading lean in that bank and as I watched the live data, I was the voltages on it were only going high not low, so I changed it. Then immediately I started getting a code saying the heating element on my bank 1 sensor 1 was not working, but I so I replaced that O2 sensor. I don't know why I didn't change the last 1 yet but within days I started getting a misfire on cylinder #2. I tried swapping the plug wires around to make sure I didn't have a bad wire. **BTW I installed new plugs and wires a month ago, Delco Irridium plugs and Bosch wires. Immediately after swapping the #2 wire the code switched to a P0300 code. I had a mechanic scan the vehicle with a real scanner as I was advised to diagnose the exact problem instead of throwing parts at it until I figure it out and he said my #2 ignition coil was bad. I asked why it said "random misfire?" and he said " oh it will say that too" so I replaced all 8 of them. I reset the ECU and it ran fine for the rest of the day. The next day 40 minutes after starting it the check engine light came on and I started getting the P0300 code again. The misfire is obviously felt. I am waiting for the mechanic to get back to me to do another scan but I'm afraid if he guessed the first time this time will just be another guess. Does anyone have any advice? Also wanted to ask if the 2013 5.3l flex has an EGR valve? I've looked with no luck finding it but I'm looking for an old school EGR, and I don't know if the look different these days. I'm willing to fix the thing properly and with good parts but this is driving me nuts. Oh BTW I did check for vacuum leaks, cleaned my throttle body and my MAF sensor. I thank you for any help offered
