matching factory tint
DaddyJackson
Im the head installer for Tintmasters Motorsports in Grand Forks, N.D. We must tint sum 20-30 sets of front rolldowns a month at $100 a set. Some of u guys say $100 is to much and i would agree if the windows were to be simply tinted in the vehicle. We remove all windows to be tinted which makes for a superior factory look. We charge $100because of the labor rate(2 hrs start to finish.) Oh...and for those of you still wondering....factory gm, ford, dodge and other trucks/suvs are factory tempered at 18%To match the fronts is difficult because the glass is not 100% light transmitting. We use 3M 20% to "match" the rears, which in the end works out to match almost perfect considering the 4-6% light blockage, on the front rolldowns, caused by the shatter resistant layer of film baked into the factory glass. Sorry to ramble on....all in all i would recommend 20% on the fronts to match the rears of the vehicle. Hope this helps anyone still beating themselves up on what % to go with. Later
tv559
Madera, CA
I pay $60 for the front windows with lifetime warranty and the guy usually finishes in 20-30 Minutes any longer than that then there proly taking breaks lol
Josh
Milwaukee, WI
^ he's right. the oem tint is exactly 18%
x2
I had 15% installed and it matches pretty good
Narco
Atlanta
32% on top of the factory 18% dropped the rears down to 8%
i put 20% on the front but it actually meters out at 15% - wish i had gone a little darker on the front
coles1189
Bay Area
I used to have 20% on my silverado and it matched perfect
Was only $50 to install
Try to work with different shops on prices and theyll normaly go for it
ecordell
CordellDesigns.com
Merica
coles sounds right, 20% should make it match pretty damn close....
Narco
Atlanta
tell them 20 and you should be spot on. in my experience, tint always meters darker than what you ask for anyway. i had 20 put on my fronts and they meter out at 15%.
jESse
i like cheese
michigan
i got 15% on mine. you can only tell its slightly slightly darker from inside if you really stare at it. paid $80
T-Giv
Colorado Springs, CO
Guys keep in mind with the tint two things: A) The factory "tint" is actually privacy glass from GM. The windows are dipped in a substance for that smoked look. That is not actual tint sheets. You can't scratch it like you can tint. B) When matching the front two windows consider how much light that windshield is going to let into the front of the truck. In order for them to match as closely as possible they need to be slightly darker than the factory smoked glass. The smoked glass is right near 18% in tint so the best match you will get is 15%. Just my .02.
glazar
