LQ4 replacement heads
mci007
Laguna Hills, CA
I have a 2004 Tahoe with a 2000 LQ4 6.0 Liter, it has the original cast iron heads, I still have the original 4.8 Liter motor that came out, can I use the aluminum heads from the 4.8 for the LQ4 engine.
The 4.8 Liter heads have a stamp on them that says 862.
Can I have the aluminum heads gone over and install larger valves and springs to work with the LQ4, or will the stock valves be fine.
I also at a later date would like to add a cam, I have heard that adding a good cam really wakes up the LQ4 motors.
Any thoughts.
BOSS
The People's A D M I N
Dallas
Any thoughts.
Interesting questions....let us know here if you find the answers out bro, hope someone with some exp can help
B
03_Denali
Gulf Breeze, FL
You could, and it would be a nice bump in compression. However they will not flow as well as a set of 317's ( stock LQ 4/9). Look for a set of 317's and have them milled .040" or you can opt for a set of 243's, but that will set you back more. Really it boils down to what you want out of your set up.
Greg
TIM Z
DMAX Power
Navarre Ohio
Cast iron heads on a 6.0 ?????\
Yes, a cam defintley wakes these motors up!
Go with comp cams. Youll prob have to change valve springs depending upon the lift of your chosen camshaft. No biggie.
Get a cam / tune / stall and your tahoe will be a hot rod.
M
mci007
Laguna Hills, CA
I really want a hot rod, I have 4:11 posi in the rear already, This thing is really quick with the 4:11's but i want more, I want quickness, speed is fun but quick is a blast, anyhow, so 317's and a comp cam, i have to keep it smog legal, so i cant go buck wild, how far can i go and keep it legal.
03_Denali
Gulf Breeze, FL
Since you have to stay smog... I would go with a corvette z06 cam and springs (you will need new longer pushrods too) then save for a turbo or supercharger kit. The z06 will give you a nice boost over stock and it is a proven cam for FI.
M
mci007
Laguna Hills, CA
How do i measure for new push rods, or will the place i get the cam from know the measurement based on the cam i select.
blueflamed03
Oklahoma
317's can be had pretty much anywhere. While you are having the machine shop go through them, look for what cam you want. A Comp, to TR cam comes to mind. Then buy the correct springs, to match the cam. You can use factory length pushrods, just get hardened pushrods. A cam will really wake it up, but you didn't mention if you replaced the stall converter? I suggest doing a converter, and add the biggest tranny cooler you can fit. A converter, with your exsisting 4.11's will REALLY wake it up, even without the 317 heads and cam.
M
mci007
Laguna Hills, CA
Im checking with the speedshop that made my converter for me, I have a 2000 LQ4 with a 4L60 trans and because the crank is a half inch longer i had to have a custom torque converter made. Thanks for all your help.
DH24YUKON
