loud clunk or grind when starting off coming from front driveshaft area
pt1965
columbia,sc
just had my posi track rebuilt due to normal wear and tear. 168k. now the front diff may have problems. if i start off normally it makes a loud clunk and if i stay on it will grind or growl. it doesnt do this in any other gears and if i start out slow its ok. i even pulled my boat up the ramp slowly with no problems. this is in 2w hi but it seems like somethings trying to engage in there. also, when its parked, i can rotate the front driveshaft, is this normal? i thought i should stay engaged like the rear.
pt1965
pt1965
columbia,sc
ok, the loud clunk is the drivers side motor mount failure! probably putting the driveline in a bind causing the other issue. going to get that replaced and then see if theres any other problems.
pt
brice715
