Losing Hvac fan speeds.
GMT800 SUV/Trucks
You might want to update your signature and put Silverado in with the 2001 Z71, because we don't know if is a Silverado or a Tahoe, unless of course you think that ALL parts are the same for each.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Vin 11126218
BY VIN# came up with
GM#22807122 $72.82
FOR THE MATEING CONNECTOR WITH LEADS. USE PART NO 15862656. RESISTOR IS CORRECT WITH 2 MOUNTING HOLES. IF OE IS CAST 52408586. OR. 52418121, AND HAS 4 MOUNTING HOLES. USE PART NO 22807123 $85.24
1yesfan
those are not cheap. ha ha Rockauto has them 1/3 less, if I knew which one was which for the truck
1yesfan
Yea I was just going to pull it and look. I should have done this when I replaced the darn cabin filter though I was fine with just #1 setting not working at that time, now that 2 is dead I have to put it on 3 and with ac on, gets a little cold.
GMT800 SUV/Trucks
You can also punch in part numbers at Amazon and save on shipping but make sure it is an AC Delco part and not aftermarket. @915_Tahoe is quoting you the price he sells them for at his job.
Debdoll
