Loose steering feel, lower steering shaft?
Truestyle Scott
was yours U shaped on both sides? Looking at pictures online it looks like some are and some are not. Mine is U shaped on both sides and that 1" that i measured was the thickness inside that U shape. Mine was probably a mr gasket as well.
Any difference in steering feel? My rack rattled pretty bad but to move it by hand was pretty tough, so you said yours didnt move but it mightve if you shook it hard enough. Or when you unbolted that passenger side, was that mount pretty loose? Mine was super loose.
Well anyway, it added support for the rack so you should be good as far as that goes. For me, its pothole season so my steering is getting worked over and is still solid.
denalianyone
NYBlackLade08
New York
Yes my steering is firm now. I didn't check the mount when I loosened the passenger side bolts. But as an extra measure it can only help with this booster in. Yes the booster was u-shaped and barely budging when trying to straighten out.
Wake
Stafford, VA
I'm battling the same symptoms as you, everything new under the front end other than inner tie rod ends and lower control arm bushings. I'm starting to wonder if it is the steering rack itself that might need replacement at 74K miles.
The rack is about the only thing left that I can see that could be the issue. I'm not sure if there is an adjustment on them like on the previously used gearbox.
Well I changed the rack last week and that tightened me up to what I expect the steering response to be.
When I removed the stock rack I couldn't tell that anything was wrong with the bushings, if there was it wasn't apparent. I'm starting to think the rack itself was worn out.
About $240 from Advance Auto, apply 20% coupon, and $120 core. Not too bad and the AA Cardone brand is a lifetime warranty, hopefully I won't have to use it again as it's a bit of a PITA and need an alignment afterward.
CrashTestDummy
Pearland, Texas
It will be interesting to see how that spring spacer works down the road. I'm thinking that might put some side load on the tube the rack runs through, possibly causing issues later on. Hopefully the tube is stout enough to handle some side loads. Many are not.
08grey
Thats a great find. I have been looking for that for some time. The spring spacer didn't work for me.
Sent from my SM-G950U using Tapatalk
MGrieme
If you try them will please let me know how to install them and if they fix the problem.
smittomatic
River Falls, WI
No, just a looseness in the wheel. Mine feels really nice now. We just got back from a 2500+ mile road trip too and the "fix" held up.
chartersj
Right on well I'm glad it has fixed the problem you had. I'm still chasing a bump steer problem. I have had the suv to 3 different shops including an alignment and they all tell me everything is tight and in spec. But yet the steering wheel still shakes over bumps...
MGrieme
So I replaced the bushing shown in this write up (http://www.brakeandfrontend.com/hyundai-mdps-coupling-replacement/). I used the bushing out of this kit (http://www.ebay.com/itm/Arm-Bushing...ash=item3d3da3deb0:g:olQAAOSwB-1Y3pmh&vxp=mtr). The old one was sloppy and slide right off. The new one I had to lube up to get on, I couldn't believe how big of a difference it was. $50 is pretty steep considering I probably won't replace the other 2 as the rubber is not cracked so I do not believe there is anything wrong with them. I tried the spring booster first and it made a difference but replacing that bushing was a much better repair for my hoe.
08grey
Nice find
Charlie21ny
