Looking for info on my 03' Denali suspension
wade
I hear my vehicle comes with some autoride or self leveling system. I can not find anything about it online.
Id like to know how it works, etc.
I just know when I tow a car on a trailer with my Denali, it still squats a lot in the rear and I hate it. Seems like others don't squat as bad.
NathanJax
Vacation Nathan
Jax, Fl
W
wade
thanks. I just went out side to look for the compressor. I can't see nor hear it on start up. I hate being a noob at things.
I am not looking to lower it. Just find out where the compressor is and if it works correctly and if my shocks leak.
NathanJax
Vacation Nathan
Jax, Fl
It will be on the drivers side right behind the rear wheel.
Mine kicks on for about 4 seconds when I first start the vehicle...
W
wade
i will go check it out. thanks.
if its broke. I heard on here Arnotts sells this stuff for a good price
---------- Post added at 06:20 PM ---------- Previous post was at 06:15 PM ----------
Ok, found it, thanks! I started truck and can't hear it. I heard an electric whine sound, i assume thats the fuel pump when I first key over the ignition though.
Is the sound of the pump sound like any ordinary electric air pump? Any kinda diagnostics to test it?
W
wade
I can't hear the pump at all. Not sure how loud it is IF it did work. I assume its dead. :(
Max
Mile High
Denver
Could have the sensor links adjusted all the way out, put a multimeter on the compressor and have someone start it up...should show some voltage if you see constant and it doesn't drop for a bit your compressor is probably out.
W
wade
not sure where or what sensor links are. But, when I turn truck on, and pulled an air line off the suspension, i heard no air being pumped out even when the rear end was squatting.
W
wade
i checked the 3 i found to check on google search. all looked fine. what else can i do?
Tribalbreak
WARminster PA
im having the exact same problem... no compressor kicking on.... WADE where are the fuses that you found to check?
Tribalbreak
WARminster PA
thanks wade, im thinking no luck on the pump coming on for me... when i turn the truck on i can hear a click back by the compressor but the compressor is not kicking in...
veteran111
