Leveling Kits and Wheel/tire sizes and offsets.
SHO_OFF
Hey guys, I just picked up a 2007 GMC Yukon Denali AWD and I'm looking into leveling kits. I understand that you can run a leveling kit (Rough Country 2") and not worry about changing angles, but where are you ordering the 1" blocks for the rears?
Also, after adding the leveling kit, what is the largest wheel and offset you can run? I'm looking at the 33"/12.5/20" Atturo Trail Blade MT tires that actually measure about a 32.5" and 2 different wheels I'm going back and forth on.
Can I run a 20x12 -44 or will there be too much rubbing/trimming? The other size is a 20x10 -12 (or -25 if they'll fit). Also, will the 33" tires that measure 32.5" fit, or will I need to order the 285/50/20 tires?
dreww2001
STL
I have a RBP level kit and run 305/50 which is a 32” tire on 20x10 -24 we had to do a lot of trimming even into metal in some places on the 10 so a 12 wide would be hard to fit.
dreww2001
STL
Also they sell kits on eBay with rear 1” blocks it’s the only place I’ve seen them
Rango
I have a 2in RC and run 285/70/17 on stock rims. Nitto G2 Tires on a 2012 Tahoe 4x4
Drok
Cold place in the north
Im running 275/60/20 duratracs which i think they’re just over 33”. My offset is between +15/+25 and +30/+40 i forget what it is and thats all i see on the site for the options for my wheels
Im leveled at 2.5/1.5 only minor rubbing at full turn which has been taken care of.
scottd
