leveling kit
customlll
Winnipeg
I am planning to install a leveling kit with 3" front and 1" rear lift and get my factory 22" Tahoe LTZ wheels powder coated black and use LT285/50R22 Nitto Terra Grapplers. What would be the best leveling kit? And will I have any rubbing issues?
cjweb11
Houston TX
A 3"F/1"R leveling kit will give you a slight cali lean, which is maybe the look you are going for, 2.5"/1" will be "level", in which case the CMM kit is very popular.
I feel like I've seen some threads on here, but I'm not exactly sure what 3" front kits people used, tho you should mindful of CV angles above 2.5" level if you have 4x4.
Shouldn't have rubbing issues w/ a 2.5" or larger lift/level w/ 33" tires, wheel specs may or may not play a part in that tho
edit: I just noticed this under 2015+, still not used to this subforum being up top, I was speaking about NNBS
Silverado MAX
FL
I'm interested to see what you go with, looking to do the same thing to my Tahoe. Subscribed
Trickystick19
